Search instead for
local page MX from remote not display
Hi, i have configured on meraki mx the web access on the firewaal parameter but if i will connect from remote i not receive login page.
I don't find specific document for this problem on meraki sites.
Can you help me?
Thank
10 REPLIES 10
Re: local page MX from remote not display
Hey @Aondio_Carlo, I'm not too sure I understand your problem, however, I assume it's that you're trying to access the local status pages of your Meraki appliances by VPN into your network?
Are you able to ping the management IP of your Meraki devices when connecting from the VPN?
Have a read of this document too which outlines the configuration steps required to enable remote Local status page access and some common troubleshooting steps; https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M....
And it works locally? So you've set this:
If so, the only conclusion I can think of is that it have something to do with the settings on the firewall. If you're MX is the external firewall, you just have to put in your WAN IP-address and that should work.
Anima Sana In Corpore Sano
helpful comment? Get me some kudos Smiley Happy
Hi, i don't have the choice remote page.
I have only the localpage configuration.
Regards
Can you share a screendump what you see in "Network-wide -> General -> Device configuration" ?
Hi, this the stamp
And does it work locally? Have you enabled it and tested it?
"Enable or disable access to the local device status pages at my.meraki.com, switch.meraki.com, wired.meraki.com. For MX's, this disables access from the LAN. Configure MX remote access here."
You see a little box when it is enabled, which forwards you to you L3/L7 firewall rules. Have you set any of those?
If I understand your question correctly - this excerpt from the documentation explains what to do -
Controlling Remote Access to the Local Status Page
On MX/Z1 series devices, by default access to the local status page is only available to devices via the LAN IP address(es). However, it is possible to allow access via the WAN/Internet IP as well.
  1. Navigate to Security Appliance > Configure > Firewall > Layer 3 > Appliance services.
  2. In the field for Web (local status & configuration), enter "Any" to allow access from any remote IPs. Or enter address ranges in CIDR notation, separated by commas, e.g. 192.168.13.73/32, 192.168.47.0/24
  3. Click Save Changes.
Make sure you note the username/password you have set for accessing device local pages.
Hi, yes i have tested local page from lan and it's ok.
I don't have firewall 7 rules
Because i don't have remote access choise?
Regards
In addition to what the others suggested you may also need to set the Security Appliance>Firewall>Web (local status & configuration) with the IP(s) you'll be connecting from.
