install forticlient to work with ssl anyconnect on azure
Abechara
i configured anyconnect on azure and worked with anyconnect client on meraki ssl saml config,
any way to configure forticlient to work instead of anyconnect on meraki saml azure config ?
1 Reply 1
BlakeRichardson
Forticlient will not work with Anyconnect. If you want to replace Anyconnect with a Fortinet VPN service you would be best to ask in the Fortinet community.
