Dears
greeting
MX device is not working in a properly way , i confirmed that the problem is not from configuration how can i change the MX device
Create a support case. They wil assist you
All the details you should need are here: https://meraki.cisco.com/support/#policies:return
Contacting to technical support at Meraki dashboard.
