how does MA-RCKMNT-KIT-1 look like?
Dhimz
Have you ever bought MA-RCKMNT-KIT-1 ? how it's look like, could you give me a picture?
it's compatible for MX series with desktop/wall mounting type?
Malik122
This is all that it seems to be, 5 screws and 5 rack nuts. All for around $100
https://meraki.cisco.com/product/security-sd-wan/appliances-accessories/appliances-accessories-mount...
7 Replies 7
jbright
Quick internet search shows this picture. Looks the same as the Catalyst 9300 rack mount kit, which is what the MS390 is based on. This would not work with any MX firewalls. The larger MX firewalls (MX84 and up) have rack ears already attached to them. Their are 3rd party rack mount kits for the smaller MX firewalls.
rackmount.it have by far the best rack mounting kits for Meraki gear.
https://www.rackmount.it/products/regulars/cisrack.html
BlakeRichardson
A cheaper option for rack mounting if you have the space is just buy a simple rack mounted shelf. If you want the ultra tidy Marie Kondo look then the rackmount.it kits are the way to go.
Dhimz
Okay noted, thank you all
Malik122
shark92651
$100 for 5 cage nuts and screws. What a bargain...
Ryan_Miles
The MA-RCKMNT-KIT-1 price has been drastically reduced thankfully and now has a list price of $2.01 USD.
