any way to disable auto vpn in meraki between 2 hubs in the same organization ?
Solved! Go to solution.
Yes, Support can do this for you. Please open a case and they will help you out.
Going sideways, you could also look at creating VPN firewall rules.
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
