devices on the same VLAN not able to communicate
Mactep
To have more IP addreases it is set up with /23 or 255.255.254.0 mask. And for some strange reason 192.168.2.X do not see 192.168.3.X devices and vise-versa.
Please advise.
6 Replies 6
ammahend
are they on wireless ? is client isolation enabled under firewall and traffic shaping ?
Prestont
we might need more information.
wired or wireless?
how are you trying to communicate with each other. Ping? if so, is firewall on the computer allowing it. are they connected to the same switch or dose it transverse a firewall?
for a very simple test connect the two computers to the same switch and try to ping each other. also if across diffrent switches is the trunk set to allow that vlan?
Have the devices with the problem got the same (and correct) subnet mask of 255.255.254.0 ?
DarrenOC
It’ll either be a subnet mask issue or devices have wrong DFG
Mactep
They indeed have the same and correct subnet mask of 255.255.254.0
CoreyDavoll1
If they on separate switches, make sure that the ports that connect all of the switches together are trunked with the correct vlans.
