We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
helo, can i configure template in meraki for only content filtering bind all network into it and let the other configuration available from all devices itselves ?
Solved! Go to solution.
Bound networks will pull all of their configuration from the template with the allowance for some network specific overrides.
There is no way to pull only certain configuration from the template.
HI @Abechara refer below document:
Managing Multiple Networks with Configuration Templates - Cisco Meraki Documentation
