dear all,
I would like to implement the mx84 by using the both wan ports. 1 port will be used for internet only and the second port for a internal wan connection where all the company sites are connected. Will this setup work?
Solved! Go to solution.
For the company WAN, connect this is a LAN port. Enable a VLAN, and use the VLAN for doing the routing.
https://documentation.meraki.com/MX/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Applia...
