client VPN router
Macsen
Just browsing
client VPN router
We're setting up a client VPN on an MX84 and when we connect the given IP by the VPN AND the router IP are the same. Is this normal?
5 REPLIES 5
Macsen
Just browsing
Sorry, to clarify, the client IP and router IP are the same
AjitKumar
This is what I understand.
You are trying to connect to MX84 as client VPN from  remote location.
The Client VPN connection is successful.
However when you do a "ipconfig" on your pc. The IP Address and Gateway IP Address is same?
Is my understanding correct?
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Not quite ipconfig but when I use the mac network settings it shows me my IP and that of the gateway are the same/
AjitKumar
Hi
Are you sure?
They should be in the same range but need to be different.
Is your VPN working meaning are you able access resources from your office network?
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
The IP is the same. Any DNS cached stuff I can access but nothing "new"
