Z3C does not register on the meraki dashboard
NDIAYE
Hello .
I had to reset my Meraki Z3C and since then the led is displayed in white but the Z3C does not register on the meraki dashboard.
Some suggestions please
2 Replies 2
Bruce
If the LED is solid white then the device believes it is registered to the Dashboard. If it’s not appearing in the Dashboard then it’s time to call support as there is probably something on the back-end that has ‘gone a little wrong’ (technical term 😀). They may well be able to fix it quickly and easily.
NDIAYE
ok i will contact support to see what they will say .
