Z3 - change routes
FlyingDutchman
Z3 - change routes
I have a challenge with the following setup:
  • Z3 to MX250 - default DNS server = corporate
  • The default route on the S2S VPN settings for the hub is disabled (=local internet breakout on the Z3)
  • Telefon service for Cisco Webex connects to voipserver.company.com
  • Corporate DNS server has an internal IP for voipserver.company.com that routes the VoIP-traffic internally via MPLS to the VoIP-provider
  • Public DNS also has an IP for voipserver.company.com that points to the public Expressway of the VoIP-provider for external clients
How do I setup the Z3/ network so that all Z3's connect to the public instead of the corporate IP of the VoIP-Provider?
Thanks in advance!
6 REPLIES 6
UCcert
Are you over thinking this?  Can’t you create a new vlan and dhcp pool that assigns a public dns IP address?
Darren O'Connor | uccert.co.uk
@UCcert I think @FlyingDutchman wants to use their internal DNS for internal servers, but not for the VoIP server.  However they have a DNS entry for the VoIP server on their internal servers that points to a suboptimal IP address.
Therefore the only options I can think of are:
  • Remove internal entry for VoIP server and use public expressway for all connections
  • Allow remote users to connect to VoIP server via existing MPLS route
  • Maintain a second internal DNS server with only a subset of internal entries (not including the VoIP server) and point the VPN clients to that
  • Somehow filter the responses the DNS server gives, so only internal hosts get the private VoIP server entry, but VPN hosts get the public entry <--- can this be done?
Unless of course I am overthinking this!
UCcert
@cmr  😆
I think you’re right.
KarstenI
The forth option that @cmr mentioned would work well, this feature is named "DNS views" and is supported in BIND, but sadly not on Windows Server DNS.
So the best long-term solution would be not to use the same domain for internal and external resources. The internal resources should be better migrated to a different domain or a subdomain of company.com.
EDIT: Wait ... just the moment I pressed "Post" I remembered there was a new feature that does exactly what DNS views in BIND are doing, the DNS policies:
https://docs.microsoft.com/en-us/windows-server/networking/dns/deploy/dns-policies-overview
These can be used for this, but are not that easy to configure.
Hi @KarstenI & @cmr ,
this is certainly an interesting approach that I will gonna test.
I'll get back as soon as possible, thanks!
You could configure Windows 10 NRPT - DNS resolution policy.
Configure the policy to send voipserver.company.com to public DNS servers (like 8.8.8.8) and let everything use the default configured DNS servers.
