I'm planning to migrate HA MX84 to HA MX100 with minimal downtime.
https://documentation.meraki.com/MX/Other_Topics/MX_Cold_Swap_Replacing_an_Existing_MX_with_a_Differ...
As document above, should I go for Method 2 as downtime will only happen when I swap the WAN/LAN cable?
From my understanding, If I go for method 1. The connectivity goes down after I remove the old MX in the network and will come back again when the new MX finished firmware upgrade and configuration sync.
Please check the procedure if any wrong.
1. Create Clone Network from existing Network
2. Add new MX100 to Clone Network
3. Config warm spare on Clone Network
4. Unplug WAN2 from the old MX84 and plug into WAN2 on new MX100 for firmware upgrade and configuration sync.
5. When MX100 is ready on Clone network. Move all WAN1/LAN cables from the old MX84 to the new MX100.
6. Re-enable Site-to-Site VPN
7. Delete old network
Thank you
