Z3 - Using wrong VLAN as source on RADIUS requests
Grumples
Hello all.  I'm trialing some Z3 appliances.  My Z3 has a default VLAN (192.168.50.1) and VLAN2 for voice (172.16.50.1).
When I first setup the Z3, I didn't have the voice VLAN created.  And when I setup a wireless SSID with RADIUS authentication, it worked great.  But since adding the 2nd VLAN, my laptop will not connect to this same SSID.
I was poking around my RADIUS server, and I found System Events like this:
A RADIUS message was received from the invalid RADIUS client IP address 172.16.50.1.
So, for reasons that I haven't been able to determine, the RADIUS requests from the Z3 are going to my RADIUS server with a source IP = 172.16.50.1 (Voice VLAN) when they should be going out with source IP = 192.168.50.1.
On my SSID, the VLAN Assignment = Default (1).  I can't think what other setting that I need to look for to correct this.  But yet I feel like I'm missing something really simple.
Anyone else have experience with RADIUS and multiple VLAN on the Z3?
Thanks, much.
Jerome_EVAGroup
If I remember correctly, the behavior is to pick the interface with the highest VLAN for radius trafic
I remember I used to configure a dummy VLAN 1000 for this purpose
Jerome_EVAGroup
Grumples
@Jerome_EVAGroupYour memory is good, indeed.  I setup dummy VLAN 1000 and now my laptop is connected.  I hope Meraki considers this a flaw or bug that will be corrected.  But, the main thing is, this works and is a solution I can replicate on each Z3.
Thanks!
Some devices let you configure an "Alternative Management Interface" to control which one is used for RADIUS.  Not sure about the Z3.
https://documentation.meraki.com/MR/Other_Topics/Alternate_Management_Interface_on_MR_Devices
