Wrong information shown in client-page, after FW update
MarcP
Hi all,
wondering if someone else has got the same problem... Very bad for our helpdesk... Also opened an case at meraki support, but would like to know if you have the same.
For testing, I updated 4 sites yesterday to the newest stable Firmwareversion (MX 13.36 - MX65)
Since then, all of them are showing within the Client page:
  • no IP
  • wrong VLAN
  • wrong usage
If I use the Tools-tab and check the arp-table, then it´s shown correctly.
Clientpage:
ARP-Table:
MarcP
OK, got it....
It is not showing any information, until traffic has been caused from the devices (none nativ vlan devices! Native vlan devices are shown correctly all the time)
Now, since this happened, everything is shown correctly, but only, back to the time when the update has been done.
1 REPLY 1
MarcP
OK, got it....
