I'm using an MX84 security and SD-WAN connected to a 2960 cisco switch. the Win server 2012 is connected to switch which are all on the same subnet. Workstation cannot authenticate and connect to the domain once i connect the MX84 but work well once i change the router to the old cisco 19xx. I didn't set any VLAN on the MX84 i used the single LAN settings.
I will appreciate any suggestion how i can solve this
Solved! Go to Solution.
Is everything in the same VLAN (aka is there a single subnet)?
What is doing DHCP? Any chance you have two devices doing DHCP (Windows server and MX) by accident? If the MX is doing DHCP it will need to give out the IP address of the Windows DC as the DNS server. It should also give out the domain name being used by AD.
Can you ping the server?
Did you use the same subnet on the mx as you used on the 19xx?
Did you verify the arp tables on all devices
yes i can ping the server and also used the same subnet on the MX just as the 19xx
Your Workstation is also connected to the same switch? Then they should not even traverse the mx but communicate directly using the switch.
the workstation is connected through wireless and i can ping the server from the workstation.
i tried connecting the workstation directly to the switch with a LAN cable and still can't join the domain when the MX is connected.
Thanks so much Philip, i noticed both the MX and Window server was doing DHCP. I added the windows server as the name server on the MX and the was able to associate the workstation to the domain.
Thank you.
