Why doesn’t Meraki block VPN applications?
jOMeraki2
Why doesn’t Meraki block VPN applications? This is ridiculous! I’ve already blocked them using the content filter, yet it still can’t use Layer 7 to properly block VPNs. This is so frustrating. What’s the point of having it if it can’t handle such scenarios? You might say it’s because of port 443, but even the most popular VPN apps aren’t getting blocked. My employees are using them freely, as if there’s no firewall in place. It’s extremely annoying
1 Reply 1
RWelch
Blocking VPN outbound/ IPVanish
Sharing this link in the event it might help you.
