IP V4, and V6 on my WAN1 !!!?????
HaniAbuelkhair4
I found this on my MX merkai and not sure if its OK
I have only WAN1 with both IP's V4, and V6
Is this OK and tried to disable IPv6 on my WAN could not find way to do that
Any advise
I have complains of slow internet
Really appreciated your help
But i could not find that option
16 REPLIES 16
https://documentation.meraki.com/?title=MX%2FNetworks_and_Routing%2FIPv6_Support_on_MX_Security_%26_...
Just edit Wan interface configuration And you will be able to disable It.
Its not an option
And on the Address and VLAN's you can see the WAN interface at all
What firmware version are you running?
I see, let me perform a test.
@HaniAbuelkhair4
Ypu should to edid your VLAN to disable that:
Click in next.
Yes its disabled already for the VLAN
But the main issue is my WAN is getting V4 and V6 IP address at the same time using WAN1 only
Maybe because its already disabled
But the WAN is getting v6 IP
So, there is one more option. Open a case with Meraki support. 😅
 I fixed slow internet disabling  ipv6 on the local vlans. Any chance you have that enabled?
Local VLAN's are disabled already
its enabled on the WAN and getting both v4, and v6 but there is no option t disable V6
Brash
Your MX is receiving an IPv6 address on the WAN because the ISP is distributing one via DHCP6.
There is no way to disable the MX from receiving this address.
If you believe it's causing an issue, contact your ISP and ask that they disable IPv6 on the link. Or you could try contacting Meraki support and see if they can disable it on the MX from the backend (not sure if this is possible or not)
