Whitelisting an IP for access to the network
Padraig
I have a public IP address I want to whitelist for remote access to the network. I can only see whitelisting for URLs. Is IP whitelisting possible on Meraki?
7 Replies 7
KarstenI
Are you talking about Rremote Access VPN to the MX? I am not aware of any config to restrict the VPN-clients IP.
Not sure if it is worth the effort, but if you authenticate the VPN-user with RADIUS, you could filter on the RADIUS-Attribute "Calling-Station-ID" which is the IP of the remote client.
EDIT: I just remembered (and quickly confirmed that this is also the case with MX version 15.37) that the MX does not send this RADIUS attribute. So this "workaround" will not work as it would for example with a Cisco ASA/FTD!
I don't understand the intent of your question.  Can you explain what you are trying to achieve?
Padraig
I have a PC and other devices at a particular Jobsite and I want to remote into this jobsite to access these devices from my office location. I only want access to be allowed from my PC in my office, no other PCs.
If you have an AP you can add it to the sites network, or use the client VPN.  Are neither of these possible for you?
Padraig
Ok. What has the AP got to do with this? I am not in the same LAN.
You can have an AP where you are using the MX at the site as a concentrator, so you end up on the LAN
