Welcome to your AI Assistant
RWelch
Active now in my dashboard - perhaps it's active in your dashboard now too? 😎
JonoM
Meraki Employee All-Star
Very exciting to see the AI Assistant starting to show up in the wild 😀
If anyone wants to know more about the tool and how to opt-in, take a look at our knowledge-base article.
As with any AI, feedback on the answers it provides is essential to help it improve, so please make sure to provide details on why any response is good or badclipboard_eff0053768ba2a64f0ce151f14f8316b1.png
17 Replies 17
RaphaelL
No and I want it !
BHC_RESORTS
It's an early opt-in. Looks...interesting...
BHC Resorts IT Department
JonoM
LucasLe
I can't find AI Assistant in my dashboard or even in the "early access", is it due to the "meraki.cn"?😂
RWelch
According to the feature release announcement, "This initial release will be a controlled availability launch in the Americas."  The link below was the announcement a week or so ago (if interested).
Cisco AI Assistant Now Available in the Meraki Dashboard!
LucasLe
Oh I see, thanks
BHC_RESORTS
Not amazingly accurate so far. Tried one of the built in prompts to "List any firmware updates for my routers" and it is showing data from 8 years ago. Not only that its showing existing upgrades, not what is supposedly available.
The AI ​​needs to learn as the database is updated, be patient and the accuracy should gradually improve. 😉
BHC_RESORTS
Agreed, more so just a commentary on AI in general how it is a buzzword but still not amazingly useful (to us at least). I just tried the "Show me the Top 10 most utilized APs" and it listed them based on serial number. Who has the serial numbers memorized? The data was wrong also, I'm not sure what it was showing but it wasn't the number of connected clients to the AP listed. So then I tried "Show me the Top 10 most utilized APs by name" and it showed me the SSIDs, with "Online clients" with a seemingly random number. Not sure what it is measuring, but it wasn't the number of connected clients.
I also tried "How do I optimize/improve my current wifi?" and it just summarized some of the links in documentation. I would have expected it to analyze the data in the dashboard to show something like "devices connecting to this AP frequently reconnect, perhaps that area needs additional coverage" or "this AP has been jammed on 2.4 ghz for the past week, try adjusting the power".
These are just some basic built in things that don't seem to have been tested at all. I would have liked Cisco to do some internal testing before releasing this, as right now it doesn't really highlight any benefits.
maligator
Been trying different searches but I continually receive "I am unable to retrieve the <what I am requesting information on> due to a permissions issue related to the client IP address. Therefore, I cannot provide the <subject> details at this time. ..., please check the Meraki Dashboard directly.
JamesT91
I get the same, I believe it down to the restricted Org setting on which IPs can use the API (under Organization > Settings > Login IP ranges), I temporarily disabled this and then the AI was able to query my network.
What I haven't found yet is any documentation around what IP range(s) we will need to allow in our Org for this AI Assistant to work.
JamesT91
Update from support:
Being that our AI Assistant feature is still in the test phase, we are still working on some of the configuration aspect and working out some of the bugs on the backend. I have brought this issue to the attention of our senior management team to take a look at on the backend. In the meantime, can you try adding the following subnet ranges to your login IP configuration?
• 64.62.142.12/32
• 158.115.128.0/19
• 209.206.48.0/20
• 216.157.128.0/20
Buya
When will this feature be available in the EMEA?
Dunky
Same question - UK here.  Not showing in Early Access
nicdc01
Finally here in my EU Instance 👀
JamesT91
Thanks for heads up - also available in a few of the Europe hosted Orgs that I have checked just now.
Buya
Yes finally available in NL
