Warm Spare best practice.
I have a few questions.
What is best practice when setting up warm spare?
Can you only use the same model number as a warm spare?
I understand that you would normally have redundant ISPs feeding each MX. But what if you only have a single ISP? Do you connect the warm MX to the main MX? And when you have an issue with the main you manually make the switch?
Accepted Solutions
5 REPLIES 5
Re: Warm Spare best practice.
You will need the same MX model (MUST)
+Warmspare need to be in the same model,
+If you have a single ISP , just connect ISP to a hub or switch (in the same VLAN) then connect from switch to both MX in warmspare.
+Warmspare can do in NAT mode or VPN-Con mode
FYI
@RichardChen1 wrote:
Check this out:
https://www.willette.works/mx-warm-spare/
Yeh... There's falsities in that and I would not recommend you follow that guide. There are some good things in there, but the whole heartbeat thing is not truly possible and very misleading.
