WAN IP's
Unexus
WAN IP's
Hi, we're moving over to a MX67 and I'm busy with the configuration.
I have
  • 1 internet connection with WAN 5 IP's available.
  • 2 LAN's
I would like to have something that is called in our current router a WAN IP Alias, 1 phyiscal IP connection, 1 static WAN IP address configured and a few static IP Aliases.
Goal:
Traffic from LAN1 to the internet is identified on the internet with WAN IP1
Traffic from LAN2 to the internet is identified on the internet with WAN IP2
Is this possible with the MX67 and if so, how?
Or do I need to use one of the LAN ports, switch it to WAN and connect my internet via a switch to Meraki WAN1 and WAN2?
Regards,
Frederik
2 Replies 2
You cannot apply this to LAN ports but to a subnet.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
You can only PAT to 2 IP's , the ones assigned to the MX wan Ports.
1:1 nat you can use also IP's that are not assigned directly to the wan port.
So you would be able to use 2 IPs if you are able to connect 2 wan ports to the isp router. Yes you could use a switch for that if the isp router dont have 2 ports
