WAN Connections.
collosa
WAN Connections.
Hi All!
Can one use two different ISP as backup for a High-Availability Pair setup?
BR
Collins
8 Replies 8
Yes you can.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
collosa
What I am asking is if I can use
ISP1 as primary on the HA on Vlan 888
Both ISP2 and ISP3 as secondary on the HA on Vlan 777
StevePF
How about using SD-WAN policies to configure preferred WAN interface on specific VLAN.
Can you explain it better?
StevePF
Sorry I miss understood the original question. I was thinking about SD-WAN policies for a spoke/hub where the spoke MX is configured with two Internet access.  For exemple an MX68.
collosa
No worries. Thanks for your response.
The setup I am talking about is a 2XMX64  in HA and 3 different ISPs
It's not possible.
collosa
Thanks.
