Vpn Intersite Add Hubs button missing
svermoyal
Just browsing
Hi all,
i own a brand new MX 67w and 5 secure connect licence on Umbrella.
On a poc i do this summer, i've successfully connect a MX67W to my internal network.
The MX was directly connect as you can see below to umbrella.
And my Stormshield Firewall was connect to Umbrella using VPN IPSEC and it's was working fine and immediatly
On my new MX67w, i can't add hubs, the add new hub button is missing.
does somebody know why and how to solve it ?
6 Replies 6
Ryan_Miles
Do you have more than 2 hubs? The add hub link goes away if there are no remaining hubs in the Org.
Example
svermoyal
Just browsing
Not, i've no hub
And unfortunatelly no add to hub.
I try both spoke or Hub but nothing.
That is cool.  What tool did you use to create the animated gif?
ConnorL
I personally use LICEcap, it's pretty handy for KBs etc. Works on both Mac and Windows.
https://www.cockos.com/licecap/
Ryan_Miles
Thank you for the two excellent recommendations.  I'll take a look during the weekend.
