MX67 A lot of VPN changed alert
Sebast
We had a lot of alerts "VPN Connectivity Changed" into our network composed by MX450/MX67.  The status of the device is okay, but lot of recurrings alerts.  Alarms only cut a ticket after a specified delay (default 5 minutes).
Do you know why are we receiveing those alerts ?
2 Replies 2
MartinLL
You are either having issues with some of your service providors or it could be a temp. issue with the meraki VPN registrar. I would open a support ticket and have them check if the issue persists.
MLL
Sebast
We are using several Service Providers, so it's not temp but all over the place.  All VPNS are aggregated to a MX450 into a Datacenter, seems capacity/performance issue to me
