- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
View Client VPN Sessions with hostname
We have build-in windows VPN to a Cisco/Meraki Firewall and we have configured the windows clients to connect using hostname instead of the public IP address. Some clients connect to vpn1.xyz.com and some other users to connect to vpn2.xyz.com.
On the dashboard(Network-Wide>Clients), we can only view the IP addresses & MAC Addresses associated with the Client VPN sessions. Is it possible to view the clients that are connected to each hostname instead?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In that case, there is no way from the Meraki end to determine which user is connecting. The end client is going to do the DNS lookup and get the IP of the MX. Neither the MX nor dashboard would be able to see how the client got the IP of the MX.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Dennoh For Meraki in general it doesn't seem to use reverse lookup to DNS servers to identify client hostnames. Sometimes you get a name, sometimes the horrible mDNS name etc. If they are your clients then unless you have thousands, or they change all the time, do a lookup yourself or reference an asset tracking system for the MAC if you have one and then edit the client records. The Meraki network will then remember the name you have entered and show it in preference to the other options.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can't view clients by which DNS name they connected to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Not quite sure if I'm misunderstanding what you're trying to determine.
Do both of the DNS CNAMEs point to the same MX? I would think that you would be pointing to a different MX depending on which VPN hostname they connected to. In which case the clients would be listed in two separate networks. vpn1 will be for MX1 in network 1. vpn2 will be for MX2 in network 2. Each site will have its own client VPN subnet that is being used to hand out IP addresses. You could deduce which VPN they are connected to by looking at the IP address that the client received from the MX.
Even if you're using a DNS load balancer to spread out the clients, you would only see the client connecting on the network that they ultimately get routed to. However, in this case, you wouldn't really be able to rely on any of the historical numbers as users could easily be hopping from one to another.
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_Load_Sharing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@CN Thank you for your response. Both CNAMES point to the same MX/Public IP ,so the clients are sharing a single subnet to connect to the VPN.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
