Hello all,
Currently we have plan to deploy VRRP between MX85 in our DC, as drawn below :
Expected traffic flow :
we want to have full redundancy for both traffic direction by using VRRP, but there are some doubt in my head:
thank you
Solved! Go to solution.
The MX requires unique IPs on the WAN side. So, one for MX1 another for MX2 and a third optional one for the VIP.
The LAN side works differently. There are just VLANs and their associated L3 IPs. No per MX IP, nor a VIP. The single IP per VLAN will belong to whichever MX is primary.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality
When configuring routed HA, it is critical that both MXs have a reliable connection to each other on the LAN, so the heartbeats of the primary MX can be seen reliably by the spare. To ensure this connection is reliable:
so, is that means we need to have another IP public to be used on our Firewall ? and we need to have this public ip configured :
as mentioned on this link below https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#Routed_... :
No, if you look at the recommendations, what I'm talking about has nothing to do with WAN.
Your WAN IP config looks ok to me (warning - I'm just starting my first morning coffee, so brain is maybe not at 100% yet). The MX WAN interfaces need unique IPs on each unit in the HA config and another IP for the VIP. It appears you have all that in place.
What @alemabrahao is mentioning is the LAN side of the MXs. The MXs don't support LACP or STP. So, you can have redundant links like you show as long as the device on the other side supports and is running STP to prevent loops. Not sure those downstream firewalls would support that in this design.
Our recommended topology shows not connecting MXs directly to each other. I'm not sure any document specifically says not to do it. And, I personally see some value in a direct link between MXs as one more layer of protection against a dual active scenario (example topologies).
Also, VRRP is sent on all VLAN interfaces on a MX. So it would also go over the port 2 & 3 of the MXs in your diagram. There's no concept of a dedicated HA/VRRP link on a MX.
got it, so it means i could applied with this topology design below? as long peer switch device could run STP to block looping
Might just be minor omissions/oversights in the diagram. But if you have two ISPs there would be two VIPs on the MX HA pair. VIP1 = ISP1 and VIP2 = ISP2.
Also, the diagram mentions 10.10.255.x/29 in a few places. So I'm not entirely sure where that's being used or if it's just a generic reference. On the MX we refer to the VIP as the shared WAN IP(s) and not any LAN side L3 interface/SVI.
But IPs aside the rest of it looks reasonable to me. That said I would very much want to lab it up and test all failure scenarios prior to deployment.
Got it, will be applied vIPs for each ISP connection.
"Also, the diagram mentions 10.10.255.x/29 in a few places. So I'm not entirely sure where that's being used or if it's just a generic reference. On the MX we refer to the VIP as the shared WAN IP(s) and not any LAN side L3 interface/SVI."
Could i applied that scenario above ? because it still confusing me, as there are no exact documentation to applied Layer 3 redundancy on LAN side
"The MX requires unique IPs on the WAN side. So, one for MX1 another for MX2 and a third optional one for the VIP."
"The LAN side works differently. There are just VLANs and their associated L3 IPs. No per MX IP, nor a VIP. The single IP per VLAN will belong to whichever MX is primary."
Yes
