batch to install and configure anyconnect
Abechara
any way to install and configure anyconnect with a batch file ?
5 Replies 5
You just can create a profile.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/Client_deployment#How_...
But you need to install it manually.
Check it out.
.https://community.cisco.com/t5/vpn/looking-for-batch-file-script-for-anyconnect-users-for-them-to/td...
The question is a little broad to give a specific answer.  Instead, let me refer you to the deployment guide.
https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/Cisco-Secure-Client-5/admin/gui...
Abechara
i relly need to create a cmd or powershell command that install and configure directly the anyconnect client
There isn't really much to a script.  You extract out the zip file you download from Cisco, place any profile you want to use in the "Profiles" directory, and then just run the MSI with /q.
If you have a central software repository, you just run the MSI.
