Is anyone else having issues where a user can log into the VPN over wifi without issues, but plugged into their home network they cannot even reach the web?
Solved! Go to solution.
Yes, not widespread but we have seen it this week. The issue was the network interface metric on the VPN adapter was a lower priority than the wired adapter. We initially adjusted the priority of the VPN adapter to be higher than the wired, but it did not stick. Adjusted the wired adapter to be lower than the VPN adapter, and that seemed to fix it.
How does your setup look like?
Pretty standard Win 10 setup for Meraki.
Are they running the same addressing? I have seen issues with the VPN and remote network conflicting IP addresses.....
Thanks guys - this worked to fix my Cisco VPN on a Thinkpad running Windows 10 going thru a Spectrum Router or a TP Link Deco mesh system. This has been driving me nuts for years. I assigned an arbitrary metric of 5 to the ethernet and 4 to the VPN. Bingo - worked immediately and tested thru all combinations.
Happy New Year and Stay well!
unfortunately we can't seem to get the NIC metric to stick/apply. it looks right when you do a get-netipinterface, but will not work until you adjust the metric manually. Still working on it.
