VPN use Active Directory for authentication
HaniAbuelkhair4
Appreciated your support on this case
Today i have windows server been used as VPN server, and now since we have the Meraki i need to shift the VPN from the windows server to the Meraki and i still need to use the active directory for user authentication.
I found this document but my question is
 I have the following documentation and my question is
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
Do i need to to add the active directory on Log into Dashboard and navigate to Security & SD-WAN > Configure > Active Directory first then configure the VPN authentications or i have to do the client VPN authentication directly?
And can i do that in parallel to the to the existing service on the VPN windows server for easy migration ?
You only need to do the bit for client VPN authentication.
You only need to configure the bits on the client VPN tab.
HaniAbuelkhair4
Thanks for the update
Any special configuration need to be done of the AD side ?
HaniAbuelkhair4
  • If no certificate is present, it will be necessary to install a Self-Signed certificate.
  • If a certificate already exists, please ensure that it has been configured with the necessary parameters for TLS
  • is this must on the AD server .
HaniAbuelkhair4
Still i am getting error
