For security reason, I have to forward UDP 500 / TCP 4500 and ESP 50 to a secure network in my internal network where a VPN device manage a L2L vpn for this secure network. Unfortunatly I cannot use the meraki MX to manage this L2L vpn.
Regarding forwarding and the direction of traffic wouldn't you just use routes?
Adam R MS | CISSP, CISM, VCP, MCITP, CCNP, ITILv3, CMNO If this was helpful click the Kudo button below If my reply solved your issue, please mark it as a solution.
You won't be able to forward ESP. I suppose you could try a 1:1 NAT and set the forward rule to ANY... But I haven't tried this so I don't know if it would work, and you're effectively opening the whole box to the Internet, which isn't a great idea really.
Bascially you're going to have ensure you have NAT-T enabled on your VPN links. You won't be able to do this without NAT-T.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b95c6aeedfe50","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b95c6aeedfe50_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b95c6aeedfe50_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b95c6aeedfe50_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6b95c6a238cdd0","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
