VPN over another ISP
AmitPanchal
We have 2 ISP which have been terminated on the Meraki firewall. We want internet from ISP 1 and site to site VPN tunnel to be from ISP 2. I had configured preference under SDWAN but it is not happening.
Could you please let me know how can I achieve it.
Brash
Assuming you have an SD-WAN Plus license, you should be able to setup SD-WAN policies to direct Site-To-Site VPN and Internet traffic to the respective uplinks.
Malwina
Hi!
How did you apply the preference?
If possible, please refer to the linked documentation and try adding the flow preferences in Security & SD-WAN > Configure > SD-WAN & Traffic shaping:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
AmitPanchal
The SD wan preference works only with Meraki to Meraki VPN and not with non-Meraki VPN peer. So is there any other solution to this?
CptnCrnch
I don't think so unfortunately. 3rd Party VPN is kinda limited, I'm trying to avoid it as much as I can.
