SD-WAN Policy - Rule behavior /w multiple Parameters
whistleblower
is my understanding correct, that when in an SD-WAN policy multiple Traffic filter parameters like e.g. "Blogging", "E-Mail", etc. are selected, they behave in a so-called OR mechanism?
If so, would it be in general possible, to achive a requirement such as a dedicated host IP (= Customer expressions) with traffic of a special category like e.g. "Windows File Sharing" as AND mechanism in a single rule as well?
2 Replies 2
I don't think it works the way you're imagining. In my understanding, it will analyze the package and match or not the rule, if it fits the policy created, what was defined in the rule is applied, if it does not follow the normal flow.
So the answer is that there is no way to do what you want.
whistleblower
so just as I had already thought! no matter how many different entries are defined in one rule, it`s an OR behavior and the entries are not dependent on each other!
hm, hasn't any of you had such a requirement so far?
