VPN Subnet Routing
DGriff
VPN Subnet Routing
New to Meraki, I'm having a basic issue with accessing the entire available subnet through client VPN, assuming this is something stupidly obvious!
My MX64 is configured for a single LAN (No VLANs) of 192.168.0.0/19. - The MX IP is 192.168.1.1
The Client VPN is configured for 10.0.0.0/19
VPN Clients can access resources at 192.168.1.x but not at 192.168.20.x - These should both be in that single /19 LAN as far as I can tell.  I have no firewall rules or static routes beyond defaults.  Note: We can access the 192.168.20.x clients while onsite.
Any help is appreciated, thanks!
2 Replies 2
Are you sure your client machines are using a subnet mask of 255.255.224.0, and a default gateway pointing to the MX?
Uberseehandel
Also check which VLANs are actually being used.
