MX80 50% throughput
YLS
Just browsing
MX80 50% throughput
Does anyone have experience with the MX80?
We are having the issue that the throughput gets lowered by 50% compared to a direct connection with my macbook.
I saw that there are problems with this and that Meraki would fix it in an firmware upgrade, does anyone know about this?
Thank you.
11 Replies 11
WaHoO
Hi, did you try upgrading it to the latest Beta version trough Organization -> Firmware upgrades ?
Which version are you running currently ?
Regards,
Grega
YLS
Just browsing
No not beta yet,
Up to date
Current version: MX 13.28
Would you recommend to go to beta?
Thank you.
WaHoO
If you are not in critical production enviroment yes, although from my experience beta is not a good thing to run in production, but for the sake of testing I would go for it yes ...
MilesMeraki
How many active users do you have behind your MX? Are you using all the Advanced Security Features? Content filtering, IDS/IPS?
5 users
Everything is disabled at the moment.
The MX80 is getting a bit long in the tooth now.  When you connect your Mac Book directly what throughput do you get?
According to an old spec sheet I found the advanced security throughput should be 125Mb/s and it can support up to 100 users.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MX90.pdf
Are you sure you don't have any traffic shaping configured?
https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/Traffic_Shaping_Settings
Directly on the PPPOE network I get 98 Mb/s
On the Meraki I get 48Mb/s
All traffic Shaping not configured.
Does the speed/duplex settings of the WAN port match the PPPoE device?
WaHoO
Try setting speed and duplex to static instead auto.
It doesn't need to be static - it just needs to be the same on both sides.
Could be worth the try, will check with internet company., thanks.
