VPN Split tunnel on iPhone IOS
Ahmad_Qattan
i wounder if there is a way to connect an iPhone device as a client vpn for MX device, and apply the Split Tunnel.
so that any traffic for the destination LAN are tunneled, but other traffic like internet is sent directly.
i found an article for the Split Tunnel. but it describe the process for Windows and Mac OS.
no info for iPhone IOS or Android.
can anyone help, please.
https://documentation.meraki.com/MX/Client_VPN/Configuring_Split_Tunnel_Client_VPN
Nash
Turn off "Send All Traffic" with the slider button?
You can verify traffic routing properly by using something like the iNetTools app, which gives you a proper traceroute, or just comparing a google search for "whats my ip" before and after you connect to the VPN.
1 Reply 1
Nash
