VPN Registry: Disconnected on MX64
Scother
got the error below from one of my spoke for site-to-site VPN. my topology is hub and spoke, site-to-site VPNs to other spoke are up only to this particular spoke VPN is down. note that my MX64 connects directly to my ISP, and i'm using the same ISP on all my spoke and hub. the site-to-site VPN used to work but then suddenly went down. no configurations changes are made. does anyone experience this before? any solution tip is much appreciated. really need help on this.
VPN Registry: Disconnected. This security appliance is unable to connect to any VPN registries using outbound UDP port 9350.
Adam
Anytime I have that issue, and didn't make any config changes, I usually have to reboot the upstream modem/router equipment and if that doesn't resolve it I'll reboot the MX.
2 Replies 2
Adam
Scother
thanks. works for me.
