VLAN tagging on WAN
BradM
VLAN tagging on WAN
Is it good idea to use VLAN tagging on the Internet ports? I am using VLANS on my LAN connections, but should I enable vlan tagging on my MX65?
Would it be useful considering I'm using the MX65 for site-to-site to 2 other locations which are also using MX65's and have vlans configured for those LANs as well?
The settings for your WAN ports are dictated by your service provider usually.  So whatever they say you have to use to connect - that is what you have to use.
2 Replies 2
BradM
Makes sense. Thanks for the help. I will run this by my ISP
