Need help as I have a project whereby I will be replacing branch Sophos with MX64 .The problem am facing is that currently Sophos has dual links and each link is tagged with 2 VLAN's on WAN side .
How can I achieve the same with Meraki as it seems MX doesn't allow such scenario.
Regards,
Patrick
Solved! Go to Solution.
What is the use of the data vlan? And do you need it when you can use the meraki autovpn?
You can connect the wan to a switch trunk port for example vlan x ,y on port 1.
Then port 2 you can use a port with vlan x( internet to mx).
And port 3 you can use vlan y( data to your lan?)
You cant. Maybe you can use a switch to split the vlans to different ports.
Why they use currently 2 vlans?
You cant. Maybe you can use a switch to split the vlans to different ports || How does this work ?
Why they use currently 2 vlans? || One if for Internet and other is for Data .Same applies to the second link.
This is cool stuff..Autovpn gets rid of Data VLAN ...Many thanks
