What is the use of the data vlan? And do you need it when you can use the meraki autovpn?
You can connect the wan to a switch trunk port for example vlan x ,y on port 1.
Then port 2 you can use a port with vlan x( internet to mx).
And port 3 you can use vlan y( data to your lan?)
