Where is this checkbox.... I don't see it? 16.16
Solved! Go to solution.
@packetdealer selecting Single LAN puts all ports on VLAN0 - disabling VLANs. Looks like the documentation needs updating.
Your on single lan.
Select :vlans
Use VLAN checkbox?Don´t know what you mean.... hit on "VLANs" maybe this is what you are searching?
Or are you talking about VPN vlan / subnet ? Then you are in the wrong submenu.
There is supposed to be a checkbox for you to disable VLANs according to:
from https://documentation.meraki.com/MX/Networks_and_Routing/MX_Addressing_and_VLANs.
However, whether I have single lan or Vlans selected, this disable feature is not anywhere to be found.
ok thought so, the doc didn't confirm it for me so I thought this would be a place to confirm. Thank you!!
Interessting, if you configured several and want to just disable one, for testing, seems not to be the ideal way.
