Uplink with 100% loss
nverdugo
Dear comunity i have an issue with an MX-84 int hte summary reports show both uplinks with 100% loss for last 3 months.
best regards
9 Replies 9
CptnCrnch
So...what exactly is your question?!
nverdugo
i want to know, what can i do for get an real report from the uplinks like 4 mounts ago, or if is some bug
NolanHerring
Can you provide a screen shot please 😃
Nolan Herring | nolanwifi.com
TwitterLinkedIn
nverdugo
here show the 100% loss on both uplinks
The uplinks are down and cannot see the internet, do you believe otherwise?
NolanHerring
So if the MX are actually up and running, then the issue might be simple.
Go to Security & SD-WAN > SD-WAN & Traffic Shaping > Uplink statistics and add a new destination
Change it from Google to something else that you know you can reach. Change the default to the new one and uplink status should reflect that.
I had an MX once sitting behind another firewall that was blocking Google DNS, so it was showing 100% down even though it wasn't. Had to add in 1.1.1.1 instead
TwitterLinkedIn
nverdugo
thanks Nolan i follow your sugestion
regards
BlakeRichardson
@nverdugo If Nolans suggestion doesn't work and its not running on a cellular connection as suggested I would open a support case as there it not much more help the forums can provide on this particular issue.
I'm guessing your MX is running on a cellular data connection?
