The group policy is able to override AMP setting but not IDS / IPS.
There is no exclusion of IDS / IPS for particular subnet or IP address is available at this moment.
IDP / IPS works between LAN port and Internet ports, and also between VLANs (Subnets).
Thus, the setting is enabled / disabled network-wide for detection / prevention to work for securing the entire network.
The Meraki ECMS exam is now live! Test your knowledge of Meraki and become an official Cisco Meraki Solutions Specialist. More info on the ECMS exam found
here.For information regarding all of Meraki's training offerings, be sure to check out the
Meraki Learning Hub.
