Uplink configuration and per user bandwidth
DeepakChakrath
Hello Experts,
I would like to know, WAN1 bandwidth configs have any impact on users allowed upload and download speed.for example if i configured 10 meg as my WAN1 speed.will it restrict a user with 2 Meg maximum speed?I know it wont allow more than the configured speed
2 Replies 2
The wan speed doesnt restrict per user usage.
You need to set the per client shaper for that
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Traffic_and_Bandwidth_Shaping#Bandw...
CoreyDavoll1
The bandwidth selector in the uplink configuration would be the total bandwidth for the circuit.  If you have 1 user using 2Mbps on a 10Mbps circuit you should be fine.  If you have 5 users all using 2Mbps each at the same time, then you're going to saturate your circuit.  If you want to limit the amount of bandwidth a user can use, then you can set the per-client limit in the global bandwidth limits.
