Moving sites between templates
DerekH
Hi, I’ve created a new template from an existing template that our sites are bound to and I want to move one of those template bound sites to the new template. The issue is that I only see sites that are not bound to a template as options to bind to this new template. Do I have to unbind a site and then rebind it manually, I can’t just move a site To a new template in 1 step? I was trying to keep as much information per site as possible.
You have to unbind and then re-bind.
It will lose its existing LAN subnet if this is auto-assigned.
1 REPLY 1
