Unable to establish a Site to Site VPN
I'm fairly new to Meraki but I've had tons of experience in networking and b2b VPNs and I just can't seem to figure out in MX84 if your VPN is up or down.
Currently I see this
I was told that this green status is just an indication that the public ips can ping each other. I talked to the peer site and they said that they're seeing the phase 1 and phase 2 up but tunnel still down (?), which seems to be the case since I can't ping their device from my subnet.
Is there a way to filter out the logs that are only related to my vpn? I'm getting some phase 2 errors but I'm not sure if its related to my vpn
I'm really at my wits ends in here. I would really appreciate the help.
Accepted Solutions
Re: Unable to establish a Site to Site VPN
Hi @ShadowoftheDark,
This link may help regarding connecting non-meraki VPNs with Meraki's Auto-VPN.
https://www.willette.works/merging-meraki-vpns/
AutoVPN + non-Meraki VPN Integration Considerations
Only subnets local to the MX can be advertised to the remote Non-Meraki VPN peer. The subnets specifically selected as Use VPN, yes on the Security appliance > Site-to-site VPN configuration page will be included as the local interesting traffic in the IPSec exchange.
Non-Meraki VPN routes are not advertised to OSPF or BGP peers.
Non-Meraki VPN remote subnets cannot overlap with existing local, static, or AutoVPN routes. Doing so generates a Dashboard validation error when trying to save the configuration.
Non-Meraki VPN routes are not advertised to AutoVPN peers.
CMNO, CCNA R+S
10 REPLIES 10
Hi @ShadowoftheDark
I understand we are discussing about "Non-Meraki VPN" Confguration.
Constructing tunnels with Meraki Auto VPN (between Meraki Devices) or Non-Meraki VPN (between Meraki and Non Meraki) are kind of easy.
I believe the logs displayed on the Dashboard shall be relevant to your VPN only.
I could see "failed to get sainfo" event
Did you happen refer to following url (Lists down most of error events)
https://documentation.meraki.com/MX/Site-to-site_VPN/Troubleshooting_Non-Meraki_Site-to-site_VPN_Pee...
Event Log: "failed to pre-process ph2 packet/failed to get sainfo"
Error Description: The tunnel can’t be established and the following error is recorded in the event logs in the Dashboard “msg: failed to pre-process ph2 packet (side: 1, status: 1), msg: failed to get sainfo.”
Error Solution: This can result from mismatched subnets in the IPsec tunnel definitions, typically a mismatched subnet mask. Check to be sure that the local and remote subnets match up on each side of the VPN tunnel.
Cheers
Ajit
ajitsnw@gmail.com
https://www.linkedin.com/in/ajitkumarverma/
Yeah, I've checked that. We even sent out screenshots of both of our phase2's to confirm we have matching subnets and they matched.
What kind of device is the remote end?
Is either end behind another device doing NAT?
I'll ask but definitely no NAT. we're both public ips peering each other
CMNO, CCNA R+S
Hi @KRobert thanks I'll try that out.
@PhilipDAthI'm peering with Fortinet Fortigate 200D
Doe your phase 2 have more than 1 subnet in it?  If so, then others have previsouly said you need to (on the Fortinet) "Needed to build an extra phase 2 tunnel instead of putting 2 subnets in one phase 2 configuration."
Thanks I'll ask them to do that.
Finally got it to work. Thanks to everyone that replied. I finally understood how Meraki does its vpn I didn't have to include my own subnet in the list of interesting traffic only the remote and just have to enable it in my own list of subnets and filter it in the rules below.
Thanks again
Glad you got it to work!
CMNO, CCNA R+S
