Umbrella address on MX64
route_map
Hi Team
I am struggling to change the DNS address for my uplink, i use a dynamic IP address from my ISP.
please check attached
5 Replies 5
CptnCrnch
I‘m not sure I fully understand. Are you simply trying to configure the dynamic hostname, or do you want to add your MX as a Network in Umbrella?
If you‘re searching for the dynamic hostname:
https://documentation.meraki.com/MX/Other_Topics/Dynamic_DNS_(DDNS)
route_map
ChrisC83
You can change the DHCP option for all your client devices behind this MX to have Umbrella DNS.
MX DNS setting will only affect the management traffic to Meraki.
route_map
I have already done this, or should i use the actual IP addresses?
NolanHerring
Did you already set up your network within Umbrella?
Or are you talking about clicking on the pencil icon and changing your DNS to the publicly known OpenDNS IP Addresses?
Here are some guides for you:
https://umbrella.cisco.com/meraki
https://documentation.meraki.com/MR/Other_Topics/Manually_Integrating_Cisco_Umbrella_with_Meraki_Net...
Nolan Herring | nolanwifi.com
TwitterLinkedIn
