Umbrella / OpenVPN servers blocked nationally in France and Portugal
EricI
I just learned that OpenVPN / Umbrella DNS servers are blocked in France on a national level following a court order.
That creates a headache for one of our a local MXs that uses Umbrella DNS for the uplink - unfortunately the config only points to Umbrella primary and secondary servers and is effectively offline. We need manual intervention which is always fun on a remote site.
I presume MX devices depend 100% on a DNS service being available to reach management servers and have no fallback option where they are able to pull config from a pre-defined IP address.
So will Cisco launch an alternative for business customers now that Umbrella DNS is effectively dead both in France and Portugal?
OpenDNS Service Not Available To Users In France and Portugal – OpenDNS
ConnorL
As of June 28, 2024, OpenDNS servers 208.67.222.222 and 208.67.220.220 are no longer available for use to users in France and Portugal, possibly resulting in configuration fetch failures and various client connectivity issues.
Customers utilising a paid Cisco Umbrella solution should not be impacted, as this change only impacts the free OpenDNS service.
If you are utilising OpenDNS in these regions, we advise migrating to an alternative DNS provider, such as your ISP's or Google DNS. For customer utilising Cisco Umbrella that are experiencing issues, please contact Meraki Support.
9 Replies 9
Brash
Given there are specific IP and port requirements for MX cloud connectivity, I would expect the MX could at least connect to the cloud backend without DNS. That said, I've never tried it.
In regards to not being able to use Umbrella anymore, if you're a paying customer and have purchased Umbrella licenses, talk to your Meraki rep to understand what the plan is for the service in those counties.
EricI
Thanks - the uplink DNS config is changed in the dashboard for this site so if the MX manages to connect using a fallback IP address of some kind it should possibly pick up the change. It has not happened yet though. We will force a restart and see if that helps.
I have just been reading about this prompted by your link.  What are these countries thinking!
All Meraki kit can fall back to using only IP addresses for management to connect to the dashboard.  It is not ideal.  You'll get a warning in the dashboard when this mode is being used.
EricI
Now I just learned that Umbrella / OpenDNS are not being blocked, but Cisco actually pulled the plug on their services in France rather than comply with the new ruling (??). While Cloudflare, Google and Quad9 (operated by IBM) comply (?) and therefore continue to operate their comparable DNS services. What a mess. 😅
Politics.  The courts should never have placed an order on DNS operators.
Next thing they'll be issuing orders against the root name servers.
Brash
It's utterly ridiculous aye
ConnorL
EricI
Thanks for the insight.
Since paying customers also use 208.67.222.222 and 208.67.220.220 (for instance on an MX WAN interface), I presume those DNS requests that match an Umbrella network identity are allowed, and only those that do not match a network identity are denied/blocked?
ConnorL
Hey @EricI ,
That is correct yes, those with a Cisco Umbrella subscription and a correctly configured integration should not be impacted. If you are, I recommend contacting Support.
