Tried to open a case but it is not working
My MX64 has a bad port. I tried opening a case but it is not working.
Port 4 is not giving out DHCP address.
I have tried several different cables and devices.
Port 4 does not show up under the Per-Port VLAN Setting section under Addressing and VLANs.
Please advise.
4 REPLIES 4
Re: Tried to open a case but it is not working
Try accessing the locks status page. Possibly that port is disabled
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_M...
Do you see any lights on the port?
Did you call support? 415-937-6671
The port is active. It is not handing out DHCP addresses. There is a light.
Thanks for the support number.
Hi @John_D
I believe the port # 4 is configured as WAN2.
Could you please convert the port to LAN?
Security & SD-WAN > Appliance Status > Uplink
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
I think that your MX's Port 4 is working as a WAN Port. To fix this, go to the gateway of your MX from your Browser > configure tab> scroll down. and Set your port 4 as a LAN port. You will need the username and password. The username and password "you can see at the Network-wide> General > Device Configuration".
Aung Ye.
