Traffic shaping on Meraki Client VPN
JoshC1
Hey guys I have been looking over some documentation and don't seem to find how to do traffic shaping on our client VPN. What I am trying to reduce is users watching Netflix over VPN, which seems like some of them are. Is this possible with the MX100? or is there another method to do this?
ConnorL
Meraki Employee All-Star
Hey Josh,
I'd focus on trying to configure split tunnel on Client VPN rather than traffic shaping their traffic for stuff like Netflix. We've got a doc about this: https://documentation.meraki.com/MX/Client_VPN/Configuring_Split_Tunnel_Client_VPN
This would allow employees to access internal resources, and all other traffic wouldn't be routed over the VPN tunnel. It'll save you a lot of bandwidth as all non-internal stuff won't be routed over the Client VPN tunnel and instead use the client's standard internet connection. This means they could still watch Netflix for example, but it won't impact the Hub MX's bandwidth at all.
Kind regards,
Connor Loughlin
Network Support Engineer
.:|:.:|:. Cisco Meraki EMEAR 🇬🇧
For reference, many questions can be easily answered by searching our online documentation: http://documentation.meraki.com
12 Replies 12
BlakeRichardson
@JoshC1  This is mentioned in the Meraki documentation for security appliances.
" Traffic shaping rules will apply to traffic sent over an AutoVPN tunnel between Meraki devices. Please note that traffic shaping rules do not apply to traffic that passes over a non-Meraki VPN tunnel."
Full link here
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping
Based on that wording I am not sure if that only refers to site to site or includes client VPN.
ConnorL
Hey Josh,
Kind regards,
Connor Loughlin
ConnorL
Also from the same doc:
"Cisco Meraki Client VPN only establishes full-tunnel connections, which will direct all client traffic through the VPN to the configured MX. As such, any content filtering, firewall or traffic shaping rules will apply to the VPN client's outbound traffic. "
JoshC1
I think this is the way to go! Thanks!
CharlesIsWorkin
Hey ConnorL,
I like the idea of the split tunnel deal, but what about employees using their personal comps to connect? We don't have access to those...
So I kind of go back to the OP's question on this....
Why not use a split VPN so only traffic for your company goes over the VPN?
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
ConnorL
That's an awesome tool! One I've now bookmarked - thanks for sharing!
Now if I could just get Meraki to feature it on their blog I could save a lot of companies grief while we wait for AnyConnect.
ConnorL
I'll see what I can do, can't promise anything though! 🙂
I can see you don't work in sales.
JoshC1
Yeah split tunnel is the way to go and great tool btw!
Or you could exclude all 155 of their ranges from the VPN (split VPN better ...):
https://ipinfo.io/AS2906
