Traffic from not authorized categories
Huain
Hi everybody
It is appearing in our reports traffic from certain categories that shouldn't been passing through, but I cannot find a way to pin point the culprit client, any idea?
Thanks in advance
It just will  shows the categories that are being blocked.
5 REPLIES 5
You can create a filter like this on the Event log page.
Thanks for your quick answer but can I filter for the specific category?
Unfortunately not, but you can download it as a CSV and apply the filters.
Yes, I did that but for some reason, the category do no appear in the events, I gues it is because it is not blocked, It is passing, is there a way to list for category indepently of it is blocked or not?
